riverslq
Oct 13, 2020Follower
Need a rack support bracket for the MS510TX
Is there anywhere I can buy a bracket and the appropriate screws to mount this unit in a 19" rack? I know it came with brackets and screws but those were lost in the last 6 months since I bought t...
DaneA
Oct 14, 2020NETGEAR Employee Retired
Welcome to the community! :)
Found out that you have already opened a support ticket with NETGEAR Support with regard to your concern.
DaneA
NETGEAR Community Team
lotustechie
Jun 22, 2022Guide
I ran into the same situation. Were you able to find a resolution to your problem?
