boramaey
Sep 19, 2022Aspirant
Need Private MIBs for GS108Tv3
Hello, I need the private mibs for the GS108Tv3 switch to get CPU, MEMORY information. I downloaded MIB file from this web page(https://www.netgear.com/support/product/gs108Tv3.aspx#download), b...
schumaku
Sep 20, 2022Guru - Experienced User
Does this switch answer to OID outside of the public MIB, for example under the 1.3.6.1.4.1.4526 tree?
- boramaeySep 22, 2022Aspirant
It doesn't seem to respond to that oid tree.
Then, should I think that this switch is a model that does not support private mib?
