dineshkmr1088
Nov 08, 2022Follower
Need to upgrade J query (S3300-28X-PoE)
We are using Net gear S3300-28X-PoE (GS728TXP) — 28-Port core switch. We need to upgrade the J query of login page. Required technical support in doing this.
Weather it will update? if I update my firmware for switch ?
Kindly suggest for the same.
1 Reply
Current firmware in place? GUI page System > Management > System Information
Rationale for this request please? Example: We have run a vulnerability assessment (software, engine, ..) and received this report. "..."
Without such complete information, we're just community members here, not formal tech support. Keep in mind the crystal ball can be on holidays. Formal answer will always be to ensure to operate the current firmware for your devices.
Start here https://www.netgear.com/support/ select GS728TXP ....
