aldoluck
Mar 23, 2017Aspirant
Need version of my GS724T for firmware upgrade
Hello, I have an GS724T from which I don't know what version it is. I found this solution but no place to make certain which version (1,2,3 or 4) I have. Is there I place where I can look it up? ...
- Mar 27, 2017
The model of the switch that you have is a GS724Tv2. It seems that it is also indicated on the label of the switch based from the picture you have sent me. You can download the firmware version for the GS724Tv2 switch here.
If ever the current firmware of the GS724Tv2 is an old version, I suggest you to upgrade the firmware in a ladderized manner. For example, from v1.0.1 to v1.0.2 then, from v1.0.2 to 1.0.3_30 and so on until you reach the latest version which is v1.0.3_35. Be sure to perform a factory reset on the GS724Tv2 switch after upgrading the firmware to the latest version then reconfigure it from scratch.
DaneA
NETGEAR Community Team
DaneA
Mar 26, 2017NETGEAR Employee Retired
Hi aldoluck,
Welcome to the community! :)
Kindly send me an actual picture of the serial number labeled on the GS724T switch itself via private message and I'll try to check it here on my end.
DaneA
