aldoluck's avatar
aldoluck
Need version of my GS724T for firmware upgrade
Hello,   I have an GS724T from which I don't know what version it is. I found this solution but no place to make certain which version (1,2,3 or 4) I have. Is there I place where I can look it up? ...
  • DaneA's avatar
    Mar 27, 2017
    aldoluck,
    The model of the switch that you have is a GS724Tv2.  It seems that it is also indicated on the label of the switch based from the picture you have sent me.  You can download the firmware version for the GS724Tv2 switch here
    If ever the current firmware of the GS724Tv2 is an old version, I suggest you to upgrade the firmware in a ladderized manner.  For example, from v1.0.1 to v1.0.2 then, from v1.0.2 to 1.0.3_30 and so on until you reach the latest version which is v1.0.3_35.  Be sure to perform a factory reset on the GS724Tv2 switch after upgrading the firmware to the latest version then reconfigure it from scratch.
    DaneA
    NETGEAR Community Team
ProSupport for Business
