jerryrice420
May 18, 2025Star
Netgear Discovery Tool 2.0.4 Will Not Allow Connection Selection
I can't connect to a ProSafe switch at all because the Netgear Discovery Tool will not allow me to select a connection to scan. On top of that, the default IP of the switch is not 192.168.0.329 (eve...
- Aug 20, 2025
On further analysis, I discovered 2.07 is available, and it now works.
schumaku
May 18, 2025Guru - Experienced User
This default IP address (.239 btw.) is only relevant in case there is no DHCP server in your network.
Further on I'll move you thread to the mor relevant section, since thes are in no aspect managed switches.
