jerryrice420
May 18, 2025Star
Netgear Discovery Tool 2.0.4 Will Not Allow Connection Selection
I can't connect to a ProSafe switch at all because the Netgear Discovery Tool will not allow me to select a connection to scan. On top of that, the default IP of the switch is not 192.168.0.329 (eve...
- Aug 20, 2025
On further analysis, I discovered 2.07 is available, and it now works.
jerryrice420
May 18, 2025Star
ProSafe Plus is not a managed switch?
schumaku
May 19, 2025Guru - Experienced User
Have an eye on the switch categories in this community, and check the descriptions on each section FMI.
