jerryrice420
May 18, 2025Star
Netgear Discovery Tool 2.0.4 Will Not Allow Connection Selection
I can't connect to a ProSafe switch at all because the Netgear Discovery Tool will not allow me to select a connection to scan. On top of that, the default IP of the switch is not 192.168.0.329 (eve...
- Aug 20, 2025
On further analysis, I discovered 2.07 is available, and it now works.
Wilsodg
Aug 20, 2025Guide
Appreciate this is relatively old post, but I have exactly the same issue. NDT 2.04, Win11 Pro. Loads up ok, but there is no network connection showing to select. I have ESET smart security and turn off all blocking and firewall. I can access switches using web address, and Prosafe Plus utility loads up fine (it was problematic on some Win 10 machines) and it finds (most) switches. However, I like the NDT interface and function so prefer to use that. To be clear - this issue is not that it can't find the switches - it is that it appears not to be detecting the Network cards (Wifi or Ethernet), so never gets to the scan.
- WilsodgAug 20, 2025Guide
