jerryrice420
May 18, 2025Star
Netgear Discovery Tool 2.0.4 Will Not Allow Connection Selection
I can't connect to a ProSafe switch at all because the Netgear Discovery Tool will not allow me to select a connection to scan. On top of that, the default IP of the switch is not 192.168.0.329 (eve...
- Aug 20, 2025
On further analysis, I discovered 2.07 is available, and it now works.
danielcarter
Sep 22, 2025Aspirant
I had the same issue on Windows 11. Here’s what worked for me: Run Netgear Discovery Tool as Administrator. Set your network type to Private in Windows settings. Enable .NET Framework 3.5 from “Turn Windows features on or off”. Temporarily disable your firewall or allow the tool through it. The default IP is usually 192.168.0.239 (not .329). Use a tool like Advanced IP Scanner to find the switch. Also, try running the ProSAFE Utility in compatibility mode (Windows 7). That solved it for me.
- schumakuSep 22, 2025Guru - Experienced User
Please use the current version instead of playing around with Windows 11. DotNET is considered a core component of a Windows 11 system, and can't be individually installed, disabled, or removed.
Look here: Netgear Discovery Tool 2.0.4 Will Not Allow Connection Selection | NETGEAR Communities
