AzurBlock's avatar
AzurBlock
NetGear FS726TP VLAN Creation / Tagging-Untagging ports
Hi everyone.   I am having troubles changing configuration of ports on my FS726TP. In the documentation it says that clicking under Port Number should change the Port from Tagged to Untagged. By ...
  • JeraldM's avatar
    May 31, 2022
    AzurBlock,
    Welcome to the community!
    Just to clarify, the box doesn't change from Blank to Untagged or Tagged whenever you click it?
    If so, please check if you tried the following:
    • Tried different browsers
    • Tried configuring it on VLAN1 and see if it's the same behavior
    • Updating the switch to the latest firmware
    JeraldM
    NETGEAR Community Team
