Murrayfield
Oct 18, 2019Tutor
Netgear GS105PE will not load new bootloader
I bought three GS105PE switches, let me call them switches 6,7 & 8 I purchased Switch 6 in May 2019 and it came with Bootloader V1.4.0.5-VB, firmware V1.5.0.5. PoE Passthru worked a treat. In June...
- Oct 21, 2019
Hi Schmaku
No rant intended, just frustration I guess. Thanks to all the information you have provided me I am now more equipped to make a quantifiable research into devices that I intend to use. I certainly know a great deal more now about PoE and can make more informed decisions, bring out the extension power lead and PoE injectors I guess lol.
Many thanks
Ian
Murrayfield
Oct 20, 2019Tutor
Hi schumaku,
Many thanks for the response, would it be of any help for me to provide the serial numbers of each of the switches?
schumaku
Oct 20, 2019Guru - Experienced User
Again, based on the available GS105PE firmware kits: In absence of an included newer bootloader, there can't be an intention that the V1.6.0.1-VB bootloader should be installed as part of the update procedures for now. Back to the reported problem...
Murrayfield wrote:PoE passthru worked until switch powered off and would not work when switch powered back on
...these issues are commonly caused by non-sufficient power source resp. a to high load on the GS105PE. It appears sometimes that a soft reboot does "recover" and the GS105PE does start to supply power outside of the specs. Say you power the GS105PE from an 802.3af (plain PoE), and try to power a Cat0 or Cat3 802.3af device, this will not happen correctly. Reason is that the GS105PE does require power for it's internal switch circuits, and there is not enough power. Under some conditions a warm reset/reboot does falsely apply power to the PD. The point is that most vendors are lazy or try to stick on the safe side. Even if a 802.3af PoE device does pull less power than the class default, they request Class 0 or Class 3 - typically for operational safety and reliability. Please note that these two standards don't have a granular "dynamic" power request protocol of PoE++ 802.3bt - and the GS105PE has (again to my knowledge) no such capability, too.
What switch (or power injector) make/model/PoE specs are you using to power the GS105PE?
What device(s) are do you try to power from the GS105PE?
- MurrayfieldOct 21, 2019Tutor
Hi Schumaku,
I am feeding the GS105PE Port 5 from port 1 of a Netgear GS108PEv3 running FW 2.00.08
Port 1 of the GS105PE is providing LAN and power (or not in this case) to a Netgear WN370 WAP running FW 6.0.1.0_3875.
For testing purposes I have also connected the GS105PE to Port 3 of a Netgear JGS524PE FW 2.0.1.26. The results have been the same, no PoE passthru
Many thanks
Sorry, as an addition to my most recent posting, I have also used a PoE injector and this worked fine allowing the GS105PE to power the WAP. I guess my contention is that all the componenents in the chain are Netgear and they are all the Pro-Safe product so I hope it is not unreasonable of me to expect them to work pretty seamlessly.
Many thanks for your help in this
- schumakuOct 21, 2019Guru - Experienced User
Murrayfield wrote:I am feeding the GS105PE Port 5 from port 1 of a Netgear GS108PEv3 running FW 2.00.08
Both the GS108PEv3 and the JGS524PE are only serving PoE as per 802.3af - no PoE+ as per 803.at.
Murrayfield wrote:I have also used a PoE injector and this worked fine allowing the GS105PE to power the WAP.
Whatever PoE injector that is - probably a PoE+ 802.3at device, or not fully IEEE standard compliant in case it's just 802.3af. See the KB link provided before: A PoE 802.3at switch or injector does provide enough power so the GS105PE can assign the full 15.4 W to one of the ports.
Murrayfield wrote:I guess my contention is that all the componenents in the chain are Netgear and they are all the Pro-Safe product so I hope it is not unreasonable of me to expect them to work pretty seamlessly.
Wrong expectation. You can't expect that the GS105PE does provide standard compliant 15.4 W (to power a Cat 0 or Cat 3 device) if the power source is only 15.4 W - and the GS105PE switch does (undoubtedly) requires some power to drive for it's own circuits.
===When powered by IEEE 802.3af:
The GS105PE can power up only one Class 1/2 PoE device.
Even if the WN370 Tech Specs talk of a typical power usage of only 5.1 W, the device does - like almost every other wireless access point and more PD defined 802.3af Power over Ethernet (PoE) - requesting the "full" PoE category 0 or PoE category 3 levels (15.4 W - alas the 16.4 W in the KB re wrong IMHO).
I'm convinced all similar posters claiming the GS105PE does only provide power following a reset are caused by the very same issue.Sorry, would love to provide a better explanation - however I can't change the facts.
-Kurt- MurrayfieldOct 21, 2019Tutor
Hi Kurt
Thanks for the very detailed explanation, and yes, it all makes sense, however this implies that Netgear are supplying a product that cannot perform in concert with other devices in the same product family, (after all I am only providing one WN370 from the switch) whilst actively advertising them as fit for purpose. Why provide the GS105 without external power capability if they know that it cannot provide the oomph to do the job? This means then, for me, that the GS105PE's that I have purchased are rather expensive doorstops and nothing better. Would you say that this is a fair representation which I can include as a reason on returning them to Netgear for a refund
Thanks
Ian
