bobby_k
Nov 02, 2021Aspirant
Netgear GS110TPv3 SNMP
With the older GS110TP switches it was possible to update the firmware on the switches using SNMP. Using the ng_switching MIB I believe. The new GS110TPv3 doesn't seem to support this functional...
bobby_k
Nov 04, 2021Aspirant
Thanks for the reply. I have downloaded the MIBs for the GS110TPv3, but unlike earlier switch versions that set of MIBs doesn't include ng_switching, which is where the controls for firmware updates were found. Scanning through the other MIBs in there I don't see any options for firmware options.
schumaku
Nov 05, 2021Guru - Experienced User
Not sure Netgear does continue to implement the proprietary enterprise MIBs .1.3.6.1.4.1.4526 on the newer switch models.
YeZ please.
- DanioYNov 15, 2021NETGEAR Employee Retired
Hi,
Sorry. After checking, we confirmed GS110TPv3 doesn't support FW upgrading by SNMP.
