jaflorio
Apr 08, 2019Aspirant
Netgear GS116E-200PES Gigabit-Switch (16-Port) Vlan compatibility with Cisco ASA
I'm having a problem with my Netgear GS116E Gigabit-Switch (16-Port) and a Cisco ASA 5505 firewall.
The Netgear switch is configured with 3 VLAN's - have tried both advanced port as well as basic -...
- Apr 10, 2019
Thanks JohnCarloV. I moved all connections to a Linksys switch as a test, no configuration changes, etc., and it worked everything worked perfectly - 2 Firewalls (Palo Alto) and (Cisco) serving two diff subnets - 3 VLAN's through one ISP.
This can be closed, not going to troubleshoot further. Will use the GSS116E as a regular switch, just one VLAN.
JohnC_V
Apr 09, 2019NETGEAR Employee Retired
Hi jaflorio,
Welcome to our community! :)
We haven't encountered any issue regarding the GS116Ev2 connecting to Cisco ASA 5505 Firewall. Were you able to test if it is working by default without any VLANs? If the Cisco firewall is set to trunk then you may just need to Tag the ports on the GS116Ev2 in order for the Tag traffic to pass through the switch.
JohnCarloV
NETGEAR Community Team
- jaflorioApr 10, 2019Aspirant
