MikeTro's avatar
MikeTro
Follower
Dec 08, 2015
Netgear GS116E-200PES Gigabit-Switch (16-Port)
Hi toghether,   at first i´m very sorry about my broken english. i cam e from austria and i don´t use english ver often.   my question is:   make it sense to buy an GS116E-200PES and use it wit...
  • DaneA's avatar
    Dec 09, 2015
    Hi MikeTro,
    You may use the GS116Ev2 (GS116E-200PES) with your Synology DS415+.  However, it would be best that you use a smart switch rather than an unmanaged plus switch like the GS116E.  I recommend you the GS108Tv2 which is a smart switch and it supports LACP or Link Aggregation Control Protocol.
    For more information about GS108Tv2, kindly access these links below:
    GS108Tv2 Data Sheet
    GS108Tv2 FAQs
    http://support.netgear.com/product/GS108Tv2
    Let me also share this link I found online and you could use it as your reference guide in setting up link aggregation between the GS108Tv2 and the Synology NAS.
    DaneA
    NETGEAR Community Team
ProSupport for Business
