TechBud13
Jan 30, 2021Aspirant
Netgear GS308E Managed Switch
Hi, I want to set up mirroring of all traffic to a raspberry pi. From my understanding I need port mirroring to do this, that way I don't have to use the pi as the DNS. From what I can see or find my...
schumaku
Jan 30, 2021Guru - Experienced User
TechBud13 wrote:I'm wondering if maybe I should find a router that has mirroring, this way it can mirror wifi traffic?
Forget the WiFi on your router, and deploy dedicated wireless access point(s) - so all the LAN and WLAN traffc does flow over the switch.
- TechBud13Jan 31, 2021Aspirant
I suppose I could do that, be more money, was looking to complete a project with a pi without that much spent. But it looks like I can put the switch in between the router and the modem, as long as the WLan is still connected to the router. not sure how I will access the management panel with that set up. But ordered it and will figure out what I can do to get my idea to work. Maybe go that route.
Thanks man!
