Davyvgw
Apr 02, 2022Follower
netgear gs308e
ik krijg de switch niet geinstalleerd
schumaku
Apr 02, 2022Guru - Experienced User
Where do you intend to link up the switch? Note: In case you connect the switch to a pure modem (eg. a cable modem without a NAT router), the switch will fetch the only IP address provided.
Get the Installation Guide from https://www.netgear.com/support/product/gs308e.aspx#docs and tell us the point where you are struggling with the installation?
