Hash70
Feb 16, 2022Tutor
netgear gs308t dropping frames
bought a netgear gs308t mainly for igmp multicast as my amplifi hd router was flooding the other ports when watching iptv and plan to learn about the rest of the features later on so theve been left a...
Feb 16, 2022Guru - Experienced User
Easy test is to put the bt hub on a different port.
If that port starts having dropped frames/packets, then I'd try replacing the connecting ethernet cord first.
- Hash70Feb 16, 2022Tutoralready tryed changing ports,I had g8 connected to my hub and that was dropping frames so changed it to g1,but I haven't tryed a different cat cable as its a new one but il try that now thx
- Hash70Feb 16, 2022Tutorstill dropping frames,tryed another cat cable and different port but it starts dropping right away,not sure on what else to try here
- Retired_MemberFeb 20, 2022
I own a GS308T and it works fine for me. However the traffic flowing through it is very light. I have another switch that was just flooded with transmit errors, but it was heavily used. There were several HD cameras connected to it plus a NVR and another switch with several HD cameras. I replaced it with a more powerful switch and assigned it to lighter duties. None of them shows any errors now.
