ProSys
Nov 13, 2023Aspirant
Netgear GS748Tv5 Management VLAN - LAG
Hi there! Trying to accomplish following scenario: Dedicated management VLAN with tag 80, tagged via Firewall Interface. Gave a port on the switch into this VLAN and tagged it with 80. Also g...
schumaku
Nov 13, 2023Guru - Experienced User
Management VLAN association correctly set on the LAG/trunk?
ProSys
Not sure I´m getting this right. My understanding is, that the clients should go over the LAG, the management traffic should go over the patched management port, tagged VLAN 80. Hence the LAG is untagged 1, no association with 80.
Traffic for the management VLAN is coming from a switch, which has an uplink to an interface on the firewall, that is tagged 80. This works (as long as the LAG is disconnected).
The LAG is going to a different switch, which has an uplink connected to another firewall interface into the untagged 1 network.
So there should be no need to add the LAG into VLAN 80?
But I also tried this in my desperation, tagged the LAGs through to the switch that is connected with the corresponding firewall interface, but this did not work either.
