AMCross
Nov 09, 2016Follower
Netgear GS748V4H2 and windows 10
hi will there ever be an update to smart control centre so that the graphic that shows the ports works in windows 10 and edge at the moment only IE and java can be used
- Nov 09, 2016
Hello AMCross,
I have not read any updates regarding this but this is a very good idea. I'm thinking this is just a matter of compatibility. What you can do is to post suggestions and ideas at the Idea Exchange board. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
Thanks,
JohnRo
Nov 09, 2016NETGEAR Employee Retired
Hello AMCross,
Thanks,
