realmx2
Jan 09, 2023Aspirant
Netgear prosafe switches storm control - can't enable
Hi, hopefully a simple question, but we have 2 newer s3300 switches, and 2 older GS748T switches. We are trying to enable storm control, and we configure it and then click the save button, but after ...
DaneA
Jan 16, 2023NETGEAR Employee Retired
Welcome to the community! 🙂
I suggest you to activate image 2 on the S3300 switches. Once image 2 has been activated, update it to the latest firmware version which is v6.6.4.28 then observe if the same problem will occur. You can download S3300 Firmware v6.6.4.28 here.
What is the current firmware version of your switches? Since you mentioned that it is on a much older firmware, I suggest you to update it to the latest firmware version then observe if the same problem will occur.
DaneA
NETGEAR Community Team
realmx2
Jan 17, 2023Aspirant
The S3300 switches (2 of them) are on the latest firmware, and this is happening on them. It's also happening on some older switches that have several year old firmware, so I keep thinking that I'm doing something wrong. Here's a video that shows the issue:
https://photos.app.goo.gl/QhS82RE2KYxVhHor9
