hamhock's avatar
hamhock
Netgear purchase recommendation for Intervlan configuration
I currently have one switch - GS108Tv2 and it has one VLAN enabled (20-guest).  It is located in basement next to a pfsense router.  I would like to add 4-5 more VLAN's( (IoT, printers, 2-4 wifi SSID...
  • DaneA's avatar
    May 13, 2021
    hamhock,
    Welcome to the community! :)
    You might want to consider the GC510PP Smart Switch for your SW2, SW3 and SW4.  The GC510PP has 8 100M/1G Copper (RJ-45) Ports.  It supports VLAN and all of its ports are capable of PoE+ for your Access Points (provided that the your APs supports Active PoE). To know more about the specifications of the GC510PP, kindly check its data sheet here.
    You may want to further check the vast variety of NETGEAR Business Switch Models here
    For further reading, let me share the article below:
    Active or Passive PoE, That is the Question
    DaneA
    NETGEAR Community Team
ProSupport for Business
