abermudezm
Feb 18, 2024Initiate
Netgear Switch Discovery Tool for MAC version
Netgear Switch Discovery Tool for MAC version 1.03 does not work in macOS Monterey, only the previous version 1.02 works. Please update version 1.03 so it works in macOS Monterey.
BrianL
Feb 18, 2024NETGEAR Moderator
- abermudezmFeb 19, 2024Initiate
Hi thanks for the feedback. The workaround from Apple does not help. The issue is (after checking) with the NSDT v1.03 software itself. The previous version, v1.02 works perfect but not the v1.03; so it is the software.
- BrianLFeb 19, 2024NETGEAR Moderator
