momo_01's avatar
momo_01
Follower
Apr 26, 2022
NETGEAR Switch S3300-PoE+
Hi Dear Netgear Community.
"If a loop is detected behind a port, this port will be deactivated.
After a certain time, the port is automatically reactivated."
Is this feature possible on my NETGEAR Switch S3300-PoE+ (28 Ports)?
Second thing: How can I configure the POE the following:
PoE was configured in such a way that the access points remain
in operation if the PoE budget is exceeded
and the other devices in the network deactivate the one with the highest consumption first.
 I would really really appreciate help here. I'm new here btw...
Kind Regards
Momo
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    momo_01,
    Welcome to the community! 🙂
    It seems that this somehow refers to STP (Spanning Tree Protocol).  STP is supported on the S3300 series switches.  To learn more about STP, kindly check the article below:
    What is SpanningTree Protocol (STP) and how does it work with my managed switch?
    I believe this should automatically work on the S3300 series switch. Kindly read about PoE Classes here.
    DaneA
    NETGEAR Community Team
ProSupport for Business
