tonynsx
Mar 29, 2019Luminary
Netgear XS716T management VLAN
I want to change the management VLAN from 1 to 2. What's the proper way to change the management VLAN without loosing connection? The switch is still on the factory default 192.168.0.239 address, and...
- Mar 29, 2019
Configure the VLANs first, inlcuding a test/spare untagged port to the (future) management VLAN #2, ideally with the VLAN trunk to the infrastructure/router, then change the management VLAN to #2. Then change the port (cable to the untagged VLAN #2 port), or acess it over the VLAN #2 if connected to the infrastructure.
