barrettusa
Nov 30, 2022Tutor
Newbi help needed with VLAN performance MS108EUP and GS110EMX
Just updated my home network by adding a NETGEAR MS108EUP and GS110EMX so I can have 2 VLAN's connecting my basement and upper floor with both my internet network and the Google fiber network. I thin...
- Feb 14, 2023
Quick update.
First, thank you for those that offered guidance and help!
After trying to get this working a couple more times I ended up calling Netgear support who also couldn't find anything wrong with my setup or configuration. We concluded the switch was not working correctly and so I ordered a new one and now everything is working as it should, so the MS108EUP was the issue.
I ended up getting a second GS110EMX rather than replacing the MS108EUP with the same switch as I found several other reviews that seemed to have similar issues with that switch, and I don't need the POE feature.
Thanks again!
Mark.
