barrettusa
Nov 30, 2022Tutor
Newbi help needed with VLAN performance MS108EUP and GS110EMX
Just updated my home network by adding a NETGEAR MS108EUP and GS110EMX so I can have 2 VLAN's connecting my basement and upper floor with both my internet network and the Google fiber network. I thin...
- Feb 14, 2023
Quick update.
First, thank you for those that offered guidance and help!
After trying to get this working a couple more times I ended up calling Netgear support who also couldn't find anything wrong with my setup or configuration. We concluded the switch was not working correctly and so I ordered a new one and now everything is working as it should, so the MS108EUP was the issue.
I ended up getting a second GS110EMX rather than replacing the MS108EUP with the same switch as I found several other reviews that seemed to have similar issues with that switch, and I don't need the POE feature.
Thanks again!
Mark.
barrettusa
Dec 01, 2022Tutor
After rolling back due to the issues I figured I would start again planning this solution! Here is a simple view of what I am trying to do with these two new switches. Basically, I have one cable between 2 floors and want to use that as a truck to carry traffic for both VLANs - is this possible and if so, what did I do wrong with the configuration?
Retired_Member
Dec 01, 2022
Yeah, that should work as long as you do not need access from VLAN2 to VLAN1. Also, it usually means double NATting while accessing Internet from VLAN1, but your Synology router may be different.
- barrettusaDec 01, 2022Tutor
Correct, only the Synology Router allows traffic from VLAN1 to VLAN2. Thanks!!
