kvkv
Mar 14, 2022Follower
no connection after lightning strike
hi,
we had a lightningstrike nearby and since then, there is no connection between our modem and the switch GS108PEv3. everything else seems to work on both modem and switch. I already deconnected both modem and switch from the power. when I reconnect, they both get power and lights start flashing except for the cable connected between modem and switch. any ideas on how to get things working again?
BR, Koen
1 Reply
1. what modem is it connected to?
2. did you try replacing the cable?
3. did you try changing ports that the modem is connected to?
4. everything else works if connected to them?
