ElevateCU
Mar 28, 2019Aspirant
No link lights on shared SFP ports (GS752TPS)
***EDIT***
I just discovered that the SFP ports on the switch are fine. I plugged in another switch to the SFP port, and it works just fine. The issue must be on the server side. I would delete thi...
- Apr 02, 2019
Most SFP+ ports don't allow to fix/lower the speed. Only option would be to install a pure 1G modules and use fiber, not DAC. SFP, SFP+, and fiber does not know anything about speed negotiation - different from plain copper Ethernet.
What server/OS/SFP+ network interface are we faing on the other side?
ElevateCU
Apr 01, 2019Aspirant
I have tried that, on 2 switches in the stack, using all possible shared SFP ports. In fact, I even treod using a different switch entirely (A GS752TP and an FS726T). With those switches, and the same cable, I get link lights when the cable goes from switch to switch, but nothing when it connects to the server.
schumaku
Apr 01, 2019Guru - Experienced User
FWIW - the server in question isn't a system with SFP+ ports defaulting to 10 Gb/s?
- ElevateCUApr 02, 2019Aspirant
I think you may have something there... It turns out that the port on the server is, in fact, set to 10G. I have been working with the vendor/Mfg to figure out if it is possible to change the speed to 1G instead. So far, no luck though.
- schumakuApr 02, 2019Guru - Experienced User
- ElevateCUApr 05, 2019Aspirant
The server is a SuperMicro box. I am waiting for the vendor to get details from SuperMicro. They have already had me try installing a different NIC driver, but that didn't seem to fix it. In the mean time, I have ordered 1G SFP modules and some fiber patch cables to see if that might make a difference.
