ElevateCU
Mar 28, 2019Aspirant
No link lights on shared SFP ports (GS752TPS)
***EDIT***
I just discovered that the SFP ports on the switch are fine. I plugged in another switch to the SFP port, and it works just fine. The issue must be on the server side. I would delete thi...
- Apr 02, 2019
Most SFP+ ports don't allow to fix/lower the speed. Only option would be to install a pure 1G modules and use fiber, not DAC. SFP, SFP+, and fiber does not know anything about speed negotiation - different from plain copper Ethernet.
What server/OS/SFP+ network interface are we faing on the other side?
ElevateCU
Apr 02, 2019Aspirant
I think you may have something there... It turns out that the port on the server is, in fact, set to 10G. I have been working with the vendor/Mfg to figure out if it is possible to change the speed to 1G instead. So far, no luck though.
schumaku
Apr 02, 2019Guru - Experienced User
