jsit
Dec 07, 2019Guide
Offline Registration Key
Just purchased a GS110TPv3 switch and am in the process of initially configuring it offline. Now I need a registration key. I registered it in the mynetgear.com site, but dont see a registration key there. See attached image.
I dont want to connect this switch to the internet. How do I obtain the registration key so I can activate all the features???
Hi jsit ,
Sorry about the experience on activation key of my.netgear.com.
And this probably issue of my.netgear.com is under analysis , we will update to you while get feedback from developer team.
Otherwise, I have a workaround to get activation key for you.
I will take about 5 minutes for you and No need to connect switch with Internet.
Please reference following step to get the key, it's free to get this workaround works.
1. Install NETGEAR insight application from iOS App Store,
or from Android Google play store.
2. Login with NETGEAR account which registered this switch GS110TPv3.
3. After login with NETGEAR account successful.
Please click on the switch name under "My Other NETGEAR Products"
4. Please click on the button of "Registation Key".After insight load the screen of device.
5. You will find the Registation Key(activation key)for your device GS110TPv3.
6. Please remember this key and keep it private not share to others.
Then Input the Key on Switch Local GUI to unlock all GUI functionality.
7. Enjoy with GS110TPv3.
Here is screenshot of my locally verification.
Hope it works for you.
Thanks,
Daniel.
The "click here to learn how to get the registration key" is of no help?
Not sure what the point is for not allowing the switch for a temporary Internet access to registration and update can be run. But curious because we operate switches from this class in environments (and areas) where no Internet is availabe at all - and we're concerned what will happen when we have to do a factory reset one day...
YeZ can you please shed some light here please? - DaneANETGEAR Employee Retired
jsit,
Welcome to the community! :)
I advise you to open a chat or online support ticket with NETGEAR Support here at anytime. Kindly state your concern or you may provide the link to this forum thread. Be sure that your contact number is indicated in your MyNETGEAR account. A registration key will be requested to be generated and it will be provided to you.
DaneA
NETGEAR Community Team
- jsitGuide
Allow me to respond to both responses.
- This only started occuring when I updated the firmware to the most recent version availabile right now, 7.0.2.4. Before that we had full access to all features. After is when it started forcing a registration key requirement.
- I have chatted with Netgear support for over an hour. They insisted connecting the switch to the internet was the only way to proceed and could not explain if I had to connect to the internet what the purpose of the Registration Key for offline activation was, or how to obtain it. Thus, my frustrated post on these forums.
- jsitGuide
So just to confirm, as of right now--at this current time, is there no availability of a obtaining a "registration key" to unlock the device functionality offline??
This is really frustrating. I've even have taken the switch home (which im really not supposed to do) to connect it to the internet (as directed by Netgear Support) and it doesn't even show up in Insight. Additionally I had to sign up for a trial of Insight cloud management just to get into the area where device management is. I get Negear's desire to move device management to the cloud and then charge a subscription fee for cloud management--on top of the cost already paid for the switch itself, but having a reliable way to access the full feature set offline is super critial. So now I have 12 of these switches that I can't even use. Will probably be returning them at this point. Not worth the hassle.
jsit wrote:I've even have taken the switch home (which im really not supposed to do) to connect it to the internet (as directed by Netgear Support) and it doesn't even show up in Insight.
Have none of this series at hand for a scratch test, anyway the business products should be discoverable and becoming listed under Insight Manageable Devices - and Unclaimed. This might be the issue they intend to fix, but I'm not sure.
jsit wrote:Additionally I had to sign up for a trial of Insight cloud management just to get into the area where device management is.
For discovery and registration, even for the free Insight Basic (three devices if I have it right), there is "just" the Netgear account required.
Anytjing following the registration is optional - the devices don't have to be claimed into Insight manageent. This would require to "remove" them, because of the local management is again restricted in Insight management mode (at least for swiches and APs).
I still like to hear from YeZ on these issues here.
DaneA wrote:Got an update from the higher tier of NETGEAR Support that a new firmware will be released soon (no ETA yet) that will address this issue.
Not sure on how a switch not able to reach the Internet can magically check the MyNetgear registration or fetch the required registration key automatically by a firmware update, isn't it?
The problem with the registration key must be addressed in Negear's support processes, and the ability to request the key required must be available direct to the user, without going over Netgear's support channel.
- DanielZhangNETGEAR Expert
Hi jsit ,
Thanks,
Daniel.
- jsitGuide
Thank you for the follow up. I have followed your work around to successfully retrieve the registration key and used it to offline unlock my device. Hope the mynetgear web interface is fixed soon, but using the app is a viable work around for now.
Thank you for your assistance!
