Funwithrouters
Jan 30, 2023Aspirant
Orbi 6e unable to update firmware
My Orbi app shows that there is new firmware for my top of the line 6e router and satellites , but when I click to update it, it says ‘Update Error’ after about 5 seconds. Why can’t the app update the...
BrianL
Mar 11, 2023NETGEAR Moderator
Hi Funwithrouters,
I agree with plemans. Are you still having issues with updating the Firmware? Is your Orbi network up to date?
Kind regards,
BrianL
- FunwithroutersMar 11, 2023AspirantOne of my satellites was running the old firmware and would fail to update through the Orbi app every time. In the end I was able to fix it by factory resetting that one satellite, then logging into it (with the default password) and updating through the web UI.
I still maintain that having two different passwords (Orbi app and web UI) is crazy and then having a long running password recovery bug on that web UI is shocking for a >$1000 router. The whole experience was very janky - even just having the upgrade fail from the app and needing me to use the web UI.
