ljlj83
Jul 18, 2023Aspirant
Per-port PoE stats for GS110TPP (SNMP)
Hi all,
In the web UI for the GS110TPP I can see power stats such as "Output Voltage" for each port; just go to: System > PoE > Advanced > PoE Port Configuration.
However, I am not sure where these can be found via SNMP; I already collect other SNMP data from the switch with no issues.
I am on the latest firmware of: 7.0.9.12
Using the latest MIB for that version.
The only MIB that seems to have any PoE information is: POWER-ETHERNET-MIB.txt
From that I can pull back the overall PoE power consumption but not per-port as I can see in the web UI.
Any ideas?
Thanks
Luis.
1 Reply
Only the standard MIBs are implemented. Netgear lost the ability (or the will) to maintain the Private MIBs available earlier.
