slamdunkthefunk's avatar
Mar 31, 2020
GS110TPP - can I aggregate uplink ports?
Hi there.
I'm interested in the GS110TPP Smart Managed Pro Switch.
I'm trying to determine if it is possible to aggregate (using LACP) the two 1 Gigabit dedicated copper uplink ports to a LACP compatible router?
  • slamdunkthefunk,
    Welcome to our community! :)
    It should work fine as long as the configuration matches your router. It does support LAG too. May I know if you really need a POE switch for your network?
    John
    NETGEAR Community Team
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    slamdunkthefunk,
    John
    • slamdunkthefunk's avatar
      slamdunkthefunk
      JohnC_V
      Thanks for the confirmation.
      Yes I require PoE, as I have multiple PoE wireless access points that will be be connected to the switch, as well as a PoE IP camera.
ProSupport for Business
