AbDhops's avatar
AbDhops
Permit Internet Traffic on port 443
Hello,
I have  GS716Tv3 ProSafe 16-port Gigabit Ethernet Smart Switch behind my main router. Switch is connected to webserver. I also have my own DDNS and port forwarding rules setup on my main router.
Within internal network (using computer connected to switch), I am able to access webserver over port 443.
However, if I try to access my webserver over the internet, its not getting connected. If I move webserver from switch to main router directly, its working. This makes me sure, that switch is blocking HTTPs over TCP.
I searched in GUI, but couldn't find any option to unblock it. Could some one guide me, on how to unblock this communication. Also, can I see this blockage in some log file.
Many thanks in advance.
  • schumaku's avatar
    schumaku
    Hard to imagine a switch in a default config, no routing, no ACL, no other access limitations should cause such an issue.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    AbDhops,
    What is the current firmware version of the GS716Tv3?
    Is the GS716Tv3 directly connected to the main router?
    Is your main router a NETGEAR device?  If yes, what is the model of it?
    DaneA
    NETGEAR Community Team
ProSupport for Business
