kc6108's avatar
kc6108
Luminary
Apr 03, 2019
Please update MS510TX support site with latest firmware
Please update the MS510TX support site with the latest firmware. The MS510TXPP support site has the latest version... and it's actually the same version for the MS510TX as well.
MS510TX shows version 6.7.0.30
MS510TXPP shows version 6.7.0.37
  • Hi @kc6108,
    I just got a feedback from our NETGEAR Web Content Specialist that the latest firmware v6.7.0.37 has been added to the MS510TX Firmware and Downloads page here.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
  • Also, please add the MS510TX and the MS510TXPP to the list of Models to select from when creating a new discussion.
    • DaneA's avatar
      DaneA
      NETGEAR Employee Retired
      Hi @kc6108,
      Thank you for reporting this.  I have already inquired this to the NETGEAR Web Content Specialist.  I will post here once I got a feedback.
      DaneA
      • DaneA's avatar
        DaneA
        Hi @kc6108,
        DaneA
ProSupport for Business
