Pusada1
Oct 03, 2024Aspirant
POE port swich off
Hi, I have a use for qty 2 Ports with POE, can I enable POE on the other remaining Ports? Appreciate your help.
- Oct 26, 2024
Hi Schumaku, thank you for your response. Issue resolved.
Apologies for the late response, I was travelling and was "off air" for a while.
Kind regards,
Pusada1
Oct 03, 2024Guru - Experienced User
Ports 1 thru 4 are all PoE supporting.
Pusada1
Oct 14, 2024Aspirant
Thanks for the response!
There was a typo in my msg, the question should be:
I would like use 2 ports w/o POE, is that possible?
- FURRYe38Oct 14, 2024Guru - Experienced User
I'm not sure. I've never tried to disable PoE on the one I have. Might look thru the WEB UI and see if there could be any mention of something to disable. There may not be. Try looking thru the user manual.
- schumakuOct 14, 2024Guru - Experienced User
Thanks to the IEEE 802.3af/at/be standardisation, there is never PoE power applied to non-PD devices connected. An absolute safe and no-brainer installation, not like the cheap passive PoE tech some competitors are promoting and selling to the uninformed customers.
- Pusada1Oct 26, 2024Aspirant
Kind regards,
Pusada1
