Pusada1
Oct 03, 2024Aspirant
POE port swich off
Hi, I have a use for qty 2 Ports with POE, can I enable POE on the other remaining Ports? Appreciate your help.
- Oct 26, 2024
Hi Schumaku, thank you for your response. Issue resolved.
Apologies for the late response, I was travelling and was "off air" for a while.
Kind regards,
Pusada1
schumaku
Oct 14, 2024Guru - Experienced User
Thanks to the IEEE 802.3af/at/be standardisation, there is never PoE power applied to non-PD devices connected. An absolute safe and no-brainer installation, not like the cheap passive PoE tech some competitors are promoting and selling to the uninformed customers.
Pusada1
Oct 26, 2024Aspirant
Kind regards,
Pusada1
