lcoNET
Nov 05, 2019Aspirant
Port Based Authentication Mode Enable => management web console lost
Hello, I configure a NPS, Radius Server on Windows Server which is configured to return Tunnel Attributes : Tunnel-Medium-Type : 802 Tunnel-Type. Select Virtual LANs (VLAN). Tunnel-Pvt-Group-I...
- Retired_MemberNov 10, 2019
Hi lcoNET
Welcome to Community!
Be careful, by default all ports's mode is 'Auto', that's mean all ports need to do 802.1x authentication once you enable 802.1x on global. So suggest you go to 802.1x port config page, only leave the ports that you want to do 802.1x authentication stay on 'Auto', for all other ports(uplink port, server port, or you said Admin port...) select to 'Force Authorized' mode, that's mean these ports will ignore the 802.1x process. Then enable 802.1x global.
Hope it helps!
Regard,
EricZ
Retired_Member
Nov 10, 2019Hi lcoNET
Hope it helps!
Regard,
EricZ
- lcoNETNov 11, 2019Aspirant
Hello EricZ,
I finish solving this problem on my own this way but it helps.
