i0ntempest
Jul 31, 2021Aspirant
Port-based QoS/Priortization with MS510TX?
Hi all, I'm pretty new to this Smart Managed Pro line and kind of got overwhelmed by all the advanced features and jargons. Can anyone please give some info on how to set up port based QoS priority...
JeraldM
Aug 12, 2021NETGEAR Employee Retired
Welcome to the community!
You may refer to this as your reference on how to configure Port-based QoS on the Smart Managed Pro switch. You can specify which ports should be applied under QoS> DiffServ> Advanced >Service Configuration.
JeraldM
NETGEAR Community Team
- i0ntempestAug 12, 2021Aspirant
Thanks, I'll try as soon as I get to it.
