penguinnmatt
Sep 13, 2023Aspirant
Ports dying when connected to QNAP switch
I've got a Netgear JGS524PE switch which is behaving weirdly. I have a 2.5Gb QNAP switch which I'm attaching to it. Every port I attach it to it seems to kill the port. Same wall socket I can conne...
- Sep 16, 2023This turned out to be a fault with the module in the faceplate that wasn't picked up by my original tester. I got a more advanced one and it became clear. Swapped the module and it works fine.
penguinnmatt
Sep 16, 2023Aspirant
