bsen
Jun 03, 2024Aspirant
Private VLAN Configuration with 802.1Q
I am wanting to create a dedicated vlan for my servers to communicate to a NAS backup device. The servers will use a dedicated 1gb interface on this backup network. The NAS device has 2 10gb interf...
schumaku
Jun 03, 2024Guru - Experienced User
bsen wrote:
In the vlan association setting, i select the backup vlan# as the primary vlan. I do not have a secondary vlan. But while reading through some Cisco documentation, it sounds like i should have one.
Don't hesitate to consult the fine documentation 28-Port and 48-Port 10-Gigabit Copper Smart Switches with 4 10GE SFP+ Models XS728T and XS748T Ports User Manual in the section Configure Private VLANs starting from p.272 down to p.278. Everything there what you are behind, including Private VLAN Association Settings and the Private VLAN Promiscuous Interface Settings.
bsen
Jun 04, 2024Aspirant
Thanks, yes i have read through the Netgear documentation many times trying to understand how to setup a pvlan for my network. I was reading through Cisco also because their docs normally have more details on what certain settings do, why to configure or why not good idea, & generally better at listing potential interop issues or limitations. I am trying to understand the concept of pvlan as a 802.1q on a general port.
That and then i will need the pvlan configured on a lag between the switches. But i assume this would just be adding the vlan to the lag as it is only a transit between the switches.
