RGoemie
May 20, 2017Follower
Advanced 802.1Q VLAN Configuration not working
I tried to setup a 802.1Q trunk between the netgear switch and an Intel NUC running as a VMWare ESXi server.
On the switch, i configured 2 VLAN IDs, 1 and 10.
The trunk port on the switch is member of both VLAN IDs of which both of them are set as Tagged for the port which acts as a trunk.
Port PVID is set to 1 on the trunk port.
When applying above configuration, i lose network connectivity with the ESXi mgmt interface, using VLAN1.
VLAN10 doesn't work either.
The issue is not with my Intel NUC/ESXi server as it works fine when i use a Cisco switch and configure a trunk port between the Cisco switch and the intel NUC/ESXi server.
It seems 802.1Q is not correctly working or i miss something in my 802.1Q switch configuration.
Appreciate any help.
Thx a lot.
I just want to follow-up on this. Were you able to try our suggestion? if yes, what is the result?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
- XavierLLNETGEAR Employee Retired
HI RGomie,
Totally agree with DaneA the issue is that ESXi uses VLAN 1 as a Native VLAN so by default untagged.
Just wanted to add to DaneA that in your case you should configure the VLAN 1 as Untagged (double click on the port) and the other VLANs as tagged.
Hope it helps
Xavier Lleixa
NETGEAR CBU PLM
- DaneANETGEAR Employee Retired
Regards,DaneA
