akio63
Aug 08, 2022Aspirant
Private VLANs on the GC728X and GC752X Switches
Hello Netgear Gurus, I am trying to understand how the Private VLANs on the GC728X and GC752X switches operate. I have a Terminal Server that only negotiates to 100 Mbps Full. So we constantly ...
- Aug 21, 2022
akio63 wrote:Okay you gave me two options.
Please keep in mind I'm just another community member, not a Netgear support or the like.
I would prefer to go to the Security > Traffic Control > Private VLAN > Private Vlan Port Mode Configuration config. Because this is what the documentation does request. At that point again, I would expect a different config pushed in place than a classic dot1q
This compares well to similar configurations on different switch models to support the asymmetrical VLAN configurations. And this is again a feature not supported on general dot1q configs. And this is in my understanding not a generic dot1q config - so thus I was talking about that before
Afraid again, have no test horse available. The related answers could come from Netgear switch engineering (via support), some insight could come from comparing the configs generated by the two variants.
-Kurt
schumaku
Aug 21, 2022Guru - Experienced User
-Kurt
akio63
Aug 22, 2022Aspirant
Okay I accept that answer. I will have to play around with the Security > Traffic Control > Private VLAN > Private Vlan Port Mode Configuration config. I have enough extra switches that I have a development lab to play around with different configurations. I will give it a try and see how it works out.
One question. Private VLANs are used for containing traffic within the community, from my understanding. When traffic needs to go outside of the community, say to another Private VLAN it would need to exit the Community via the promiscuous port. Then where does it go? Would it be routed by a router or Layer 3 switch to the other Private VLAN?
Thanks,
Robert
