Weise
Nov 21, 2017Aspirant
Problem with Lag AND Stack on 2ports on 2switches 728TXS
Hello, I habe 2 switches configured as a stack. And I have configured a LAG with two ports of Switch1 und two ports of Switch2. My Server has got 4 NICs, all NICs are active and configured for LAG. ...
- Nov 26, 2017
Thanks for your answer. I finally set up all one more time and suddenly everything was working fine. Expect, the switch needed one more restart.
Raphael
JohnC_V
Nov 22, 2017NETGEAR Employee Retired
Hi Weise,
Welcome to our community!
As per checking that you were able to configure 2 LAGs and it is working properly. Have you ever tried to check if the ports are not members of the previous LAG? May you be able also to try if you can just connect the 3rd LAG as 2nd? Meaning you have to remove the other one just to isolate?
Weise
Nov 26, 2017Aspirant
Raphael
