tmkremer
Apr 13, 2021Aspirant
Problems to connect with Switch JGS524PE
Hi, In the house we bought, we found an already installed home network including Netgear JGS524PE. I am now trying to access the switch with my computer. For this I have downloaded the NETGEAR Swit...
schumaku
Apr 13, 2021Guru - Experienced User
Temporarily change the computer LAN or WiFi adapter config to a static address in the 192.168.0.0/24 subnet, like 192.168.0.123 mask 255.255.255.0 default gateway .1, DNS .1. Untick a "test config after applying" or the like. Once re-gained access to the switch (e.g. following a factory default), don't forget to change the adapter back to DHCP.
tmkremer
Apr 14, 2021Aspirant
Thanks, simple solution :), but it worked. Can now connect to the Switch.
