preissler
May 26, 2025Aspirant
Product state of GS116E
Hi, I am trying to determine whether the Ethernet switch GS116E is still supported or has reached the end of its product cycle. The NETGEAR product pages provide conflicting information. The Germ...
May 26, 2025Guru - Experienced User
EOS doesn't mean the device stops working, just that it stops getting updates. So it'll still work fine.
Are you having an issue with it?
