talkingcats
Feb 21, 2022Aspirant
Propagating VLANs on a GS305EP managed switch
Hi, I have a Draytek 2765 and Netgear GS305EP. I am having difficulties in propgating my VLANs onto the switch. Any assisatnce or pointers would be really great. Thanks in advance VLANs ON ROU...
talkingcats
Thanks for your reply.
Crashed was an unprecise term. The switch waas no longer reachable.
The untagged default VLAN and all tagged VLANs were sent to port 4 of the router. Not sure what other configuration you are referring to. I have attached a PNG of the config I have done.
I#m a sofware guy not an infrastructure man and this is a home project for me. My plan here is to separate out the traffic from my WAP. But first of all I have to prove that VLANs are being propagated. So I configured Port 4 with LAN2 on the switch just to see if the tthe attached host would pick up an IP address from that VLAB. I didn't
At the moment all I see is failure and I have no idea how to track down where the pronlem is.
schumaku
Feb 21, 2022Guru - Experienced User
Ok, this was my assumption, too. Hey, it requires some apotions, these VLAN configs are not very complex for a software pro either - you can handle this!.
Now you have to put up the same config on the switch. For the trunk from the router (you did a perfect config for the port #4 there!) the similar config must be done on the GS305EP, port #5
The Gigabit Ethernet Plus Switches User Manual does show the "Manage advanced 802.1Q VLANs" (that's the mode you need for such a config) with the details on how to apply the above settings. Sorry, missed this part of the guideline before.
in general, the VLANs must be defined on the switch. The ports must be defined for which VLAN ID tags are accepted, and to which VLAN the untegged frames entering the switch port are assigned to - that's what the PVID.
Hope this helps now!
