42bCurious
Apr 18, 2023Aspirant
ProSafe JGS524 v2 --- a port is Yellow, but not passing signal …
ProSafe JGS524 v2 --- a port is lit Yellow, but not passing signal …
others are lit Green, and passing signal ...
I don't know what's wrong ...
It's Cat5e ethernet cable is a little over 160 ft ... could that be an issue?
Help surely welcome!
Thanks!
1 Reply
On most LAN ports yellow (or not green) means that it is connected to a device that has a 100 Mbps LAN port.
You can confirm this by checking the manual
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
As to "not working", a bit of experimentation will confirm if it is the port or the connected device.
