smullin
Feb 05, 2019Aspirant
Choppy VOIP on lines passing through Netgear Prosafe GS752TP
It seems like I have tried virtually everything to solve Choppyness on my VOIP. We have Cogent 100/100 and recently upgraded from a Sonicwall TZ215 to a TZ400. I have tried every setting with Sonicwall. I plugged a user from our Netgear switch directly into the Sonicwall and the problem stopped. The choppyness is only on incoming traffic. I was told by someone at Vonage Business Cloud that we shouild have an unmanaged switch instaed of a managed switch. I have been told by others that the managed switch is basically unmanaged until you configure it. Since the choppyness disappears when the user is plugged directly into the Sonicwall, it seems like the Netgear switch is the problem. (Firmware 6.0.0.31) Any suggestions?
Thank you. I restarted both the switch and Firewall and there was a vast improvement. My individual phone was worse because the cord was coiled under my phone. Once I moved it away from the phone, the choppiness stopped.
- JohnC_VNETGEAR Employee Retired
Hi smullin,
Welcome to our community! :)
It seems that you were having issues with the VoIP if it is connected to the GS752TP. As per checking, Firmware 6.0.0.31 is not included in our downloads page. May I know if you are running on beta firmware? You are correct that when a managed switch also works as unmanaged until you configure it. You may just try to reset it to factory default for you to check if that will work. Just in case that it was configured before, then you may set a backup.
JohnC_V wrote:
...e GS752TP. As per checking, Firmware 6.0.0.31 ...
...what does read like the GS752TPv2 factory initial firmware version -> https://www.netgear.com/support/product/GS752TPv2#Firmware%20Version%206.0.0.31%20(Initial%20Release)
