manlymanagement
Feb 03, 2017Follower
Prosafe Plus GS116Ev2 VLAN trunking
Hi, I would really appreciate help finding the name for the feature and where I can read regarding configuration. I require to set up VLAN trunking, forwarding the tag from source to destination ...
- Jun 21, 2017
Hi Kc1
You have to first configure the Switch to use 802.1Q Advanced VLAN, once you do this you should be able to see the Untag and Tag
Regards
XavierLL
Feb 03, 2017NETGEAR Employee Retired
HI Manlymanagement,
Welcome to our community!
To set up a VLAN trunking in our GS116E you are right you have to add the VLANs to VLAN Membership, please find below the three steps required:
- Create the VLANs
- Use VLAN Memberships to add the VLANs to the Trunk Port ( you have to mark them with T)
- Check that the PVID for the trunk port is 1 ( this is the native VLAN)
Moreover see an example in the following link
Hope that it helps.
Xavier Lleixa
NETGEAR CBU PLM
Retired_Member
Jun 21, 2017XavierLL in the link that you gave, the example shows Tagging the connection/'trunk' between the 2 switches. However, Prosafe Plus GS116Ev2 firmware does not seem to support marking ports as tagged or untagged, nor is there any way to set the PVID
...or am I missing something?
- XavierLLJun 21, 2017NETGEAR Employee Retired
Hi Kc1
Regards
- Retired_MemberJun 21, 2017
Thanks - the usability of the software on the new models caught me out - it's not obvious what you can select and what which state anything is in
https://s23.postimg.org/4b516ruxn/Clipboard01.jpg
It's not obvious [to me] which of these is selected / selectable, but knowing the function is there thanks to you, helped me sort it out
